Compression Driver and x-over Combo for Econowave build in 20” by 13” cabinet.
UPDATE 051716: my Dad is giving me a JBL 127h-2 10 inch woofer salvaged from a JBL L80 (I think) so that takes care of the woofer choice.
Hey Guys! I know Im a bit late to the econowave craze but I suddenly found myself in need of a custom small floor stander a la Klipsch Heresy because I just moved into a smaller condo. A local carpenter will build the cabs for me and my Dad will help tweak a crossover. I know that GOOGLE is my friend but I’ve been diving down into the other forums and I’m starting to get a nosebleed from the differing opinions, broken pic links and dozens of variations on this speaker build.
Some of the information available in the forums are currently 5 years old and I don’t know if there were any other advances in the crossover and materials department of the econowave so I’m asking for help to keep me current on the best choices for an econowave build. Here are the current cab plans and look of the builds I’m aiming for:
Here are some things I plan to have in the build:
Budget: In the spirit of its name, I plan to buy the most (CHEAP) value for money materials in terms of price and performance.
10” Woofer (please suggest a driver)
1” Compression Driver (please suggest)
Wave Guide (Please Suggest)
Port Holes (optional, depends on recommendations)
Crossover: Please recommend a x over schematic that I can start upon emphasis on tight lows and non-grating treble.
Focus would be on efficiency because I’lll use an TUBE 18 Watt S.E.T. I can buy a pre-built one pending recommendations or I can buy a schematic design and have my Dad build me the crossover.
I hope to get a clean 50hertz on the bass but I can settle for 60 Hz.
This will be against a wall so some boundary reinforcement on the lows may happen.
What'a a good distance from the edge of the WAVEGUIDE to the EDGE of the Woofer?
Thank you for your help!
