Berhinger pmh5000. Tr4 blown up + top221p. the TOP221p is available but not TR4 so far. Can I use a 15volt mains transformer connected to the power input at the power board? Is the original circuit a basic SMP? Thank you for any help given
Tr4 is what?
Have you got a PDF of your power supply as it is different to my version?
Found the psu schematic.
DO NOT use a TOP221p it will go BANG! TOP245 is fitted. TR4 is only an NPN driver transistor. BC848 will do if SMD or anything really.
If the secondary goes short circuit, it will not damage the primary TOP, as it will shut down.
How did it get blown up I wonder!
Berhinger PMH5000
I have the schematic. Tr4 is a small transformer running from the main bridge rectifier, through a single diode then 4.7uf 400v capacitor then on to the primary of TR4 and IC6 (TOP221p). Ic6 is a I believe a small switch mode power supply chip and regulator and from the secondary of TR4 supplies a square wave running at 100kzh probably and then smoothing cap to the main regulator section of the board to start it up.
I think that is all I can think of at the moment.
Cheers.
Cheers.
Berhinger PMH5000
I think I drew an arch from the mains plug while it was still switch on could have been a lot worse to go.
Best wishes.
Best wishes.
Berhinger PMH5000
I think I drew an arch from the mains plug while it was switched on?
Best wishes.
Best wishes.
Berhinger PMH5000
Tr4 is a small transformer used to supply the start up voltage for the rest of power supply.
I think I drew an arch from the mains plug while still switched on.
Behringer mph5000
I don't know if I am doing this right but here goes.
Tr4 is a small transformer used as a startup for the Amin power supply.
And yes I have schematics.
Tr4 is what?
- Class D
- Berhinger PMH5000 Power supply problem.
