Excellent condition.
Specs:
Price: 150 euro
Will be shipped securely.
Contact me here or by email: veselin.karavelov@gmail.com
Specs:
- 4 Digital Inputs (S/P-DIF - 2 optical, 2 coaxial)
- 1 Analogue Outputs (Cinch - fixed)
- Headphone Amplifier (6,3-mm-Jack) with Volume Control: 12 to 600 Ohm, 700mW
- Frequency Response: 20 Hz to 20 kHz
- Signal-to-Noise Ratio: > 103 dB
- Channel Separation: > 100 dB @ 1 kHz
- Total Harmonic Distortion: < 0,0015 % @ 1kHz
- Resolution: up to 24 bit
- Sample Rate: 28 to 192 kHz
- Burr-Brown Converters
- LED Indicator for chosen Input
- Colour LED for On-/Off-Switch
- Direct Current Sink: Device can be used worldwide
- Gold-plated Connectors
- Solid, Black Metal Case
- CE certified
- Valuable Switching Power Supply (12 Volts DC) included
- Dimensions: 180 mm × 140 mm × 50 mm
Price: 150 euro
