I looked through my user manual and then I searched the internet for half an hour. Either this info is not published anywhere or I'm just really stupid and can't find it.
Anyone know the type, order and q of the Behringer EP4000 high pass filter? It's adjustable - either 50 hz, 30 hz or off but I can't find any more info than that.
Might be first order...
And "off" might mean a 7Hz first order HP, at least if it is the same as the EP2500...
-Charlie
-Charlie
Ewww, first order is just about useless.
Yeah, my user manual says "off" really means 5 hz.
Thanks.
Thanks.
From the schematic, the EP2500 looks like 44hz at 12dB/oct.
Thanks for this.
I downloaded the ep2500 manual, it says it also has 30 and 50 hz filter. I assume the 44hz at 12 db/oct is the 50 hz setting? Any idea what the 30 hz setting will do?
This isn't looking too promising, I'm probably going to have to use an external filter to get what I want, but since I also need a good low pass filter too... maybe I'll keep an eye out for a used dcx.
