before I order my gainclone LM4780's....
Couple of questions...
I'm going to build 2 gainclones... one will be a 4 channel LM4780 which I simply want to use to around 70 WPC (whatever the max is)... for midranges
the other gainclone amp will be a parallel amplifier with 2 4780's per channel at around 100+ wpc paralleled for tweeters... for 4 ohm driving
1. Should I buy 8 4780 kits then? I'm assuming so...
2. Should I purchase the 3 snubberized PSU boards for this also?
3. What transformers with dual secondaries (this means I can run 2 channels of one transformer right?) should I purchase... I'm assuming the ones for the smaller non-parallel will be smaller than for the parallel amplifier
Help please?? purchasing these before the end of the night hopefully
Can I ask why you only need 70 watts for your midranges, and 100(!) watts for your tweeters. Surely you don't need that much?
In answer to your questions,
1) Yes, if you want one amp with 4 channels and another amp with 2 paralleled channels, then you will need 8 LM4780 boards.
2) Not sure how you'd wire up three PSU boards to 8 boards symmetrically though. I would have gone with 4 PSU's personally.
3) a 500-700VA toroidal should be enough for each amplifier.
Ah ok, I didn't know what type of speakers you were trying to drive.
The PSU boards are the rectifier boards. There is no difference between the two. The PSU board contains the Diodes, and capacitors.
For your 4 ohm loads, you'll want a lower voltage (for more current). I'm not entirely sure what the maximum would be (considering the chips are in parallel) but a safe voltage would be 18v secondaries (which will give roughly 25v after rectification).
Hello ther..
sorry to butt in..i just received my PCBs for the 3886 and the 4780 from Peter..
Now i am building a 3 way active monitor and am planning to use these two amps along with a Nad 320BEE..
I would want to know ur suggestions regarding the transformers VA and secondary rating ...how many trannies will i need for the 3886 and the 4780..
also which amp should power which driver..considering the load and power handling of the drivers ?
The tweeter is
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-526
midrange
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=299-492
woofer
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-315
please advise...
alright that's what I thought about the rectifier boards... the kits come with those and parts to populate the boards
