And umpteen others.
FWIW, a few points to keep in mind, as they sometimes get overlooked:
A 'clone' is a design that is specifically built to mirror the original design as closely as possible; in this case that would mean the original T27 and B110 drive units, using the original filter design, in a BBC spec. box. If you deviate from this, it is no longer a 'clone' and has nothing directly to do with the LS3/5a, being simply 'inspired [to a greater or lesser extent] by it'.
The above is not a criticism of such designs (far from it), nor a promotion of the original, just a statement of simple fact. An issue that particularly plagues the LS3/5a is that pretty much any compact 2-way is often described as an LS3/5a 'clone'. You see it multiple times on the thread referred to above. And with plenty of companies too. Which is both factually incorrect, and does everybody a disservice since as a result, nobody really knows either what is being done or asked for unless they go hunting for details, which not everybody has the leisure to do (assuming those details are even available). The point here is that these speakers loosely described as 'clones' are often wildly different speakers, so while one person might have built an LS3/5a to spec. and gives an answer, another might have built a totally different design that doesn't share any of the LS3/5a's design objectives or characteristics, and be describing that. Apples / oranges.
In essence then, it depends exactly what you want. If you want an LS3/5a, then the above is what you need: the original driver types, with the original filter and cabinet design. This is not optional if you want an LS3/5a. If you want a compact 2-way standmount and are not necessarily concerned about rigidly following the original: then there are, of course, a lot of other options, from which you can select based on your particular wishes.
