So I have a Yamaha Jog 3KJ 1997 50cc Scooter ive been playing around with and the battery has dramatically decreased in performance. I have charged it before and refilled the cells a bit, but a lot of the water has leaked out as the battery is mounted sideways. I am going to double up the seals with a old latex glove to maybe add more of a sealing to it, to prevent it from loosing all the electrolyte again.
I have read the thread about the mains desulphator, but i was too lazy to build one because i had to jet the bike and sort a few things in the shed and the battery had to be in the bike by Monday, that day being Saturday.
I just wanted it working away asap.
So thought ill use my power supply that goes up to 32V 5A. Just left it there for almost 24h now at 32V @ 200mA. Battery voltage kinda goes up and down but its at about 15V. I am going to keep cranking it. When i lower the voltage to 15 it only draws about 300mV. Ill keep cranking it with volts. Stick it back in bike later and check it again on friday and post results.
It definetaly has some hope i got a few more battaries i can play with but might be worth boosting the voltage up from my lab power supply, maybe a transformer? if knows what sort of transformer or circuit that could boost that 30V output to +/- 150VDC.
