Do not get me wrong, I had some Sound exams at the university at my times, (I am EE) but a lot of theory, FFTs, psycoacoustics and so on.
I often help some of my artists friends with their live setups, when there are free or caritative events, but on the practical side, I am less than a diletant.
However I have good practical skill on my job, with measuring instruments and so on.
So I am looking to some literature on the practical side of the job, to improve myself, mostly for respect of my friends, that are truly good artists.
An aspect of special concern is how to sistematically measure and setup the equalization of a small (150/800 p.) venue, usually a theater or an outdoor ( I know, this last is though). Right now I am doing "at hear" using the help of some really good ones (my aren´t so much) and the results are so and so. I have no problem to get some reasonably priced microphone and portable instrument in case, but I would like to start with the absolute basics.
Any help, espcially "first hand" will be highly appreciated.
the biggest problem I see is no one reads the manual to the mixer and one can see boards clipping all the time. When you point that out the response is, I read the manual it says when the red light flashes I still have 3db left (it says flash not stay on for seconds)
Most boards have a PSL or solo button that lets you adjust just that input.
You set the slider at 0 or Unity, then with the PSL button pushed down you adjust the trim to where the power meters read 0 (you can leave the sliders down during this to keep from scaring the audience)
You want everything at 0 for the peak, the kick drum is the hardest to set at 0 but it is the most important because it needs that head room.
After everything is set for 0 on the output meters I usually start off with vocals at unity gain and the instruments -12db below unity. (depending on how loud they play) and the power sliders about 1/2 way.
Once the band starts playing I just try to widen the sound and bring everyone up to the loudest player on stage.
Then check the settings again using the meters because during a sound check no one plays their loudest.
If the board has sweepable mids on vocals I will turn that up to 3-6increase and sweep the frequency until I find their voice. I usually turn the bass (80hz) down on all vocals and usually roll the highs (12khz) back since no one sings that high or low. On instruments I normally do not eq anything unless it is to cut a frequency.
One thing to remember is everyone in the audience has more experience running a sound board then the sound man
(inside joke)
That´s helpful for the mix side, thanks.
What about room (ambient) equalization? How you measure the levels ad various point of the audience? My experience is that there is tiny fraction that hears well (usually in the front/center) and the most that hear quite muddy/bad.
General complain is that the bass is not strong enough and the highs are not clear.
""hears well (usually in the front/center) and the most that hear quite muddy/bad.""
That is always a problem, if possible get the main speakers farther apart, if you have a sub it is recommended center stage is the best place for it but live sound is live sound, 10 or more sound sources you have sounds bouncing off of everything in every direction. Then you have monitors which really muddy up the sound but getting musicians to learn to listen is impossible.
I am the wrong person to ask about EQ as I never use them. My sound gigs are loud rock and roll bands and the room acoustics are out of our control. We walk around and we notice there are areas that sound bad but 99% of the rooms we run sound in were never designed for sound in the 1st place.
I do know a couple of sound guys who EQ a room by feeding a sine wave into the system and adjusting the EQ to eliminate squeals but once the band shows up all of that goes out the window.
Sub woofers have been debated since they were made, I believe they should be next to each other, preferably as center to the room as you can get or right against a wall. I know 2 completely theories there but every room is different, one can do the math and go crazy or just keep experimenting.
I do use a couple of external units
I use a Rane AC22 crossover that can add up to a 2ms delay to the sub and that seems to help the low end.
I also have a BBE 442 that lets me clear up the highs (not sure if it delays or advances the high end) by turning the high control knob on that up 2-3 clicks over the low setting it lets the horns on my peavey SP2G speakers really shine. Usually my low volume knob will be on 4 and the high volume knob will be around 6 the BBE changes the phase relationship of the drivers.
Making your own graphs from sines will take all day. For room EQ, the traditional tool is the RTA (real-time analyzer) with a pink-noise signal generator (equal energy in all frequency bands) and a 1/3 octave equalizer. You can pick up a used Behringer for $150 with a calibrated instrumentation condenser mic. I search and get them even cheaper. That will do all 3 jobs digitally. If fact, it will do all 3 jobs automatically at the push of a button. Personally, that "auto" mode never works all that well in the real world, but the RTA lets you take and average readings at multiple locations, add stored EQs, etc. It's a fundamental tool. On the other hand, it doesn't tell you much your ears can't tell you; its more like giving your ears a reality-check reference; tweeking by ear does a decent job of high/low balance, but feltcher-munson and personal tastes etc. can get you confused and into thinking a mid-scoop that sounds impressive is really flat.
That gives you energy EQ, but doesn't really tell you what's going on in the time domain. Really basic info you still need to tell what's going on is the reverberation time at different frequencies, something that gives you a real waterfall plot including the time domain. That also helps time-align your crossovers and speakers. But finding out what's going on and doing something about it are two different things. All too often it shows up room problems that you can't do anything about.
Then, once you have an accurate 'reinforcement' system, then you can start to work on each input and the mix. There a meter or LED bridge helps a lot, but your ears are really important.
Thank you for the reply,Making your own graphs from sines will take all day. For room EQ, the traditional tool is the RTA (real-time analyzer) with a pink-noise signal generator (equal energy in all frequency bands) and a 1/3 octave equalizer. You can pick up a used Behringer for $150 with a calibrated instrumentation condenser mic. I search and get them even cheaper. That will do all 3 jobs digitally. .
Could you please elaborate more on the subjext?
I understand the pink noise , but why 1/3 octave?
And which 3 jobs you mean?
Again a manual or some lterature would help I am real noob.
I did once some tests with a FFT scope and a pink noise generator, but with uncertain results..
I will look for that book maybe at the Uni library. What year is it about?
I'm sure there's good books now; "Audio encyclopedia" original edition is from 195-something.
A RTA is usually a 1/3 octave 2-dimensional bar-graph array of volume in each 1/3 octave band. Which corresponds conveniently to a 1/4 octave equalizer.
3 jobs:
1) Signal generator that can make pink noise.
2) RTA that can display what the mike picks up.
3) Equaizer.
3 jobs:
3) Equaizer.
Pick up a Behringer DSP-8024 and matching mic. Pretty cheap, pretty effective. Or the DSP-9024. like this one: Behringer Utlracurve DSP 8024 w Mic | eBay
In the old days very narrow filters were used.Thank you for the reply,
Later, through trial and error it was found that 1/3 octave worked better.
1/3 octave will not detune with room temperature changes as narrower filters will.
Good suggestion, thanks! I will have a look at the library.I believe the yellow bible, as it once was known, "Sound System Engineering" by Don and Carolyn Davies is still the best reference. I hope it was updated! E
Yes it has been updated.
Jsixis;3371144 said:Very true. One of the few times that I had very good response from the audience was the one that a friend had given me some kind of monster sub. Ita was 1000W unit, mono. I did put it in the center (where else you put a mono...) and passively mixed he inputs. Nobody ever noticed it was mono, as it had 2 x 18" drivers.
The second part of your remarkable post drives me on the Phase problem.
OK, with the graphic equalizer we might flatten amplitude, but what about phase? from your post it looks like IT IS a problem.
BTW that Sub I had wired out of phase, it was sounding much better that way.
RTA, other problems that I see...
First, small problem you probably need a RF microphome (or better a RF bridge for your measurement microphone) if you venue is less than small.
I assume you let the instrument on your rack near the graphic equalizer, hook it in on a line input of the mixer and you move around with the microphone.
Second, where to measure? OK, front-center has priority, but then?
Thanks for your update. Any reference (edition, year, etc?).Yes it has been updated.
Sound Systems: Design and Optimization: Modern Techniques and Tools for Sound System Design and Alignment: Bob McCarthy: 9780240521565: Amazon.com: Books
This book is far and away the best on the subject of tuning rooms, time alignment and system layouts in general. Nothing else comes close. Read that before you pay any attention to the advice in this thread. This topic has advanced by leaps and bounds in the last few years and I don't know another book as up to date regarding the current tools of the trade.
When it comes to tuning, when in doubt, do as little as possible. Heavy handed eq does more harm than good to your phase coherence. Time alignment usually has a lot more to do with success than eq, and anything more than a few dB at a couple bands means that EQ is not the solution. Just like with mixing, it is always better to fix the source than to do "damage control" at the end of the signal chain.
Thanks a lot for this further recommendation. Looks like it is another good one (I was reading the reviews).Sound Systems: Design and Optimization: Modern Techniques and Tools for Sound System Design and Alignment: Bob McCarthy: 9780240521565: Amazon.com: Books
About the "minimalist approach" I fully agree, in any field of "tuning".
Problem is sometimes you have to do with horrible places. This summer, just as an example, I will probably have to help with a dance show that usually we do in a fine theater (although with old sound system). But there, once you got to the idea that you need a sub , you are almost fine. This year it looks like that for economy reasons they are doing it in a sort of school basketball playground.... Lot of glass, rectangular corners, no real stage, a nightmare. They said proper stuff will be rented, but I get that there will a lot of work with the room equalization,.
- Live Sound
- PA Systems
- Basic Sound Engineering manual / literature
