im looking to take a burned active speaker (damadged amp) and create a passive speaker out of it.
the speaker is JBL 315 and it has 2ohm 14inch sub and a 8ohm tweeter.
considering I can make the right crossover to count for the different indepandance - will the result be a balanced sound ? meaning will the sub and tweeter volume be balanced or will the sub be much lauder since its indepandance is lower??
The compression driver is more than likely higher sensitivity than woofer so it will need to be padded to match the woofer. I'd be more worried about the woofer impedance. Do you have an amp that can drive a 2 ohm load?
Some specs may be of assistance:
Tweeter is JBL 2414H:
Power Rating: 35W AES
Frequency Response: 1.9kHz-20kHz
Sensitivity: 98dB (unspecified)
Impedance: 8 ohms
Voice Coil: 1.0"
Recommended Crossover Frequency: 1.9kHz
https://www.loudspeakersplus.com/JBL-2414H-HF-Driver-p/jbl-2414h.htm
Woofer is JBL M115-2:
2 ohm, 220 watts continuous.
I can't find its sensitivity rating but its 8 ohm equivalent (JBL M115-8A) is rated at 99 dB/W/m.
Impedance: 8 ohms
Voice Coil: 1.0"
Unless you’re trying to come up with a crossover theoretically, your design process will be based on listening and measuring, with the impedances and other specs. of both drivers inherent in the trial-and-error process. In other words, you‘re safe ignoring all the specs., given these are the drivers you’re working with. It’s very unlikely you’ll need to pad the woofer down, but you might benefit from filtering it quite low.
- Design & Build
- Construction Tips
- balancing component speakers with different indepandance
