Here's another comparison request (don’t you just luv ‘em!)
I’m wondering if anyone has compared the Balanced Zen Line Stage, by Mr Nelson Pass, with the SE Balanced Line amp (EB-2000/402) by Mr Erno Borbely?
While I’m have an (increasing) admiration for the work of Nelson Pass, I am attracted to the idea of using JFETs instead of MOSFETS in a pre-amp. Indeed Mr Pass acknowledges the superiority of JFETs in certain low level applications.
Incidentally, to ascertain the performance of a “passive pre” in my system I soldered a couple of resistors in my interconnects as a voltage divider, and connected directly into my amp. Obviously I can’t alter the volume, however (as my CD player has two pairs of outputs) switching between the pre-amp and the attenuated leads demonstrated the affect of the pre-amp on the signal. Just a thought for those considering going down the passive path, but wanting to see the effects before spending a lot of money on a stepped attenuator. An alternative would be to make a series of “piggyback” RCA plugs of different values, with a female and male RCA connected via an attenuator.
Pete
Pete
