How often do op amps go bad? I've got a PPI ProMOS 12 here that has extremely low output on one channel. I've removed the muting transistors and checked output at the op amp. One output is normal and the other is very low. I'm getting signal to the non-inverting input and have changed the feedback resistor's value with no change in output, still very low.
