Not quite finished yet, one up and running.
I used a pair of Alpair 7M grey, the tapered line length is approx 84 cm (slightly under optimal). Hope factoring in air coupling will add effectively 5% more length
Overall dimensions are roughly 25 X 23 X 16 cm
Listening impressions at a relatively low volume are .. the A7 is a truly great driver. Detailed midrange, just the right amount of treble, no problematic sibilance..
Jazz sounds great. Snare drums etc
Some bass present but not sure the foam I used is right. Too dense? I can hear a lot of upper frequencies escaping the exit of the line.
Will finish cab 2 tomorrow and tweak..
[IMGDEAD]https://uploads.tapatalk-cdn.com/20160621/01f9000813fdc414647af40748e6fd32.jpg[/IMGDEAD][IMGDEAD]https://uploads.tapatalk-cdn.com/20160621/12bf811cef07d4dc6243fdf5c1509f87.jpg[/IMGDEAD]
[IMGDEAD]https://uploads.tapatalk-cdn.com/20160621/a10ce2b39ff7f43dd25069ce44f0cd99.jpg[/IMGDEAD]
