Babelfish F8
Biasing up now. One channel at 485mV on R16 with dead 0V offset. Other channel 485-495mV and can't trim below 65-70mV offset.
The channel with high offset started way up around 700mV and took a lot of turns to reduce.
Anything that needs to be addressed?
.. Per last 20 minutes a little higher at 85mV with temps up.
Yes the 500ohm trim pot and 330ohm resistor.
Was getting warmer on the table so backed off at 1.75A or so to start.
Did notice that if I brought Iq up towards 1.8 then offset would go down. Almost like maybe going to 1.9 would drop things down below 50mV or less.
What odds I just moved it into position.
Warming up the other recently completed project, my 4P1L DHT preamp. What a monster. I had to put off this cutover because I was having such a fun time with it.
And on that note, just flicked the power switch. Quick ground buzz and settled in to silence and the soft pings of a heating cathode.
DHTs and Power JFETs. I am in for a good evening.
Uhmm, might have to see what ZM has to say. Although he would probably say 50mV DC offset is no worry. I am running mine with Semisouths at 1.4A Iq (smaller heatsinks), but the DC offset can be adjusted easily to near zero with an adjustment range +/- either side of 0mV DC.
if offset is positive, means lower output part isn't "open" enough, asking for higher Ugs
just put 1K trimpots in both channels
first pre-set them to mid position (confirm with ohmmeter), then solder in pcb
Amp running, sounds fantastic.
At speaker terminals with meter polarity matching speakers have -100mV.
Enjoying too much to worry about pulling trim pots at the moment. Next rainy day.
if offset is negative, do nothing
trimpot is minimized, so no use of changing it
just leave it as is, better than changing drain resistor for input JFet, and decreasing OLG
Don't expect to see Papa blushing
:rofl:
All this repeated F8 “hoopla” has me twitching and scratching 😬😬😬
Has anyone who built this one also built the Babelfish J2?
Any comments or observations between the two? MZM?
I know I don’t need any more amps to build, but I have the Semisouths.
Re-reading Pa’s F8 article just made things worse.
I’ll go stick my head back in a speakerwhile I wait…
