I pulled the SwitchPack to replace several broken solder lugs. When I pulled it I snipped the wires leaving about 1/8" of the colored insulator to simplify re-installation.
This worked ok right to the very last wire....it's the last wire that has nailed me...
The wire in question is the furthest wire on the "Test Current Transfer" switch, it is the Green wire that is the one right above the orange drop(.05/400V) that sits between the 2 structural plates at the end of the switch.
Anyway....could someone tell me where this wire goes from here?
