av400 VS. super leach amp
In MY opinion, you need to ask a question before you ever can get an answer.
If you are asking which one wins in a fist fight, then I go for the av400 because the number is so big in the name of the amplifier. Seriously,
Try again, please.
You may have your heart set on one of the two amps you listed in the title but the high power version of Rods P101 is a comparabale design. Many of the specs are right up there with the AV400 such as the rail voltage at +-70 and output at around 180 RMS into 4 ohm. Just my two cents worth.
Brian
Brian
Actually, his website states
With the full supply voltage of +/-70V (which must not be exceeded!), RMS power is around 180W into 8 ohms, or 250W into 4ohms. Short term (or "music") power is typically about 240W into 8 ohms and 380W into 4 ohms. Note that depends to a very great degree on the power supply, and a very robust supply is an absolute requirement for the maximum output."
This is a very good sounding amp and fairly easy to build. It was my first amp.
Blessings, Terry
