Hello everyone,
I have some stuff that I am not using:
(3) LM3875TF $2.50 each
(lots) Hubbell HBL5266CA 15A 125V AC plugs $8.00 each
(3) Corcom 6EHQ3 6 amp EMI AC filters $25.00 each
(lots) Panasonic TSU 680uf 250v snap in caps $1.00 each
(1) used transformer from Marantz CD63 $20.00
(1) used 16.9344mhz Audiocom ver 1.1 superclock $30.00
(tons) of Silver Mica caps 5pf to 1200pf in about 30 values
(tons) of polystyrene caps 27pf to 8.2nf in about 30 values
(lots) Fairchield Stealth diodes 30 amp 1200 volt to247 $2.50 each
(lots) IR schottky diodes 40cpq100 100v 40 amp to247 $2.00 each
I also have lots of Sanyo OSCON caps and Elna Cerafine caps....let me know what you need.
All parts new except the transformer & clock.
All pricing USD,
all parts guaranteed to work.
Please e-mail with any questions.
Kevin
All pricing USD,
Kevin
I also have all kinds of silver plated teflon coated solid wire and small AWG stranded pvc coated wire.
Please e-mail questions
I do not have Cerafine in that large a value.
The 180pf 5% caps I do have....they do not have a voltage listed, I would assume 500v. How many do you need?
Kevin
Kevin
No answer to email
No answer to my email received re availability of clock,
Is the clock still available, I am trying to find out if it will fit a Marantz SA8260 if so I will purchase, If you can supply answer to either please?
fwies@majormotors.com.au
