hi,
I am new to this forum and want to ask the members if anyone is willing to supply me with the latest eprom (or image) of the AP P1P?
kind regards, Alex
The Netherlands
kind regards, Alex
The Netherlands
Hello, my P1DD says DSP VER 1.12 then VERSION 3.22 . If l can further help don’t hesitate to ask.
Pierre
Pierre
Hi Pierre,
Thank you for you reply. Unsure if P1DD is same as P1P which is a single domain device (analog 🙂. Do you have the option/equipment to read-out the eprom?
Greetings from The Netherlands, Alex
Hello,
I don't have any equipment related to eprom, but I'm willing to get some. I heard that some eprom may failed after a while 25 years or so and it's a good idea to get a safety copy.
Nevertheless I may require some friends to help me.
What would you recommend?
Regards,
Pierre
Regards,
Pierre
Hi Pierre,
Good to hear that you plan to make a copy.
I think with a standard eprom programmer like TL866II Plus USB which you can find on Amazon etc.
The AP-P1 is very easy to open, 6 screw on the bottom and lift the cap.
Then removing the EPROM from its socket is easy.
I am willing to take a share in the cost of the eprom programmer / eprom ic.
To check which type it is I will remove the sticker and check the type of eprom.
regards, Alex
regards, Alex
