I have an Audio note Oto that I have used exclusively for over 20 years, its cosmetic condition leaves something to be desired, I have decided that it is time it received some tlc, I think there maybe a dry joint somewhere ( very occasionally a sound like the wind blowing on one channel pronounced on turning off) As I take it apart and clean it up and put it in a new enclosure (cracked facia that is no longer available) I would appreciate any suggestions for easy improvements I could make at the same time, thankyou in advance,🙂
Does the sound alter / go away when you move one of the control knobs?
First thought would be volume potentiometer (or bias / humbucker pots if fitted)
Probably deserves the best quality replacement parts that you can get.
No, change altering the controls, could it just be a loose speaker connection on the amplifier, its possibly loose. thanks for your reply
