I need hlp in building the electronics to a subwoofer. Preferably just a basic design (amplification and low-pass filter). Components list needed will be much required.
Do keep the electronics at the basic descriptions as cos I am only at that level of electronic knowledge.
Any help will be appreciated. Thanks.
choosing a sub-woofer amp depends on how much of power you need
check out this website www.sound.au.com
simple and easy to learn with all the things you need to know
from simple electronics to your filter and amp circuit
i see you are in singapore
that helps
you have rs and farnell to order from, plus your electronics shops
watch out for fakes
that helps
watch out for fakes
