If your looking for a low electrical noise power supply avoid the Seasonic S12II ATX power supply. I assume it is causing by ground loop issues. My computer's "earth" is full of RF noise in the MHz region that is when shorted with a cap a clear 50 Hz can be seen on a scope, I was wondering if anyone had some simple suggestions for getting rid of these RF spikes on the earth.
In the near future I will receive a cheap external DAC and optical cable which should resolve the issue. (Thanks to this site for the idea)
24-Bit-Audio-D/A-Wandler ADA 24 | ELV-Elektronik
24-Bit-Audio-D/A-Wandler ADA 24 39,95 EUR
Adapterkabel ODT/ODT (Toslink), 1,5 m 2,95 EUR
I bought a cheap oscilloscope (ebay duel channel 20 Mhz@60 Euros) to repair a pair of Quad 303's (didn't need it in the end) I decided to look at the noise from my PC's with reference to the Hifi's earth.
It seems a shame to go for an external DAC just to loose the ground loop issue, and I guess their are better or worse power supplies, any suggestions on Low ground loop noise power supplies. I have a lot of sound cards some reasonable, and it seems a shame to loose any use of any of the inputs.
PS my first post to this site 🙂
I reorganized the mains and have now removed the majority of the ground loop problem, some times you can be just dumb. Its now what most people would call HiFi but not perfect. The computer still introduces some ground loop effects unlike the cheap CD player I have. I hope the DAC improves the issue, but now I am not convinced the problem is the power supply as the levels could easily be the computer. Loading the ATX power supply (and I don't have all needed to hand) is too much work when I have the DAC coming. I will try to remember to update you on the relative quality and if it is as good or better than a mid nineties Cd player.
You might want to open the supply and have a look at it. A while back I had one that
was wiping out my neighbors AM radio. When I looked inside the rf filter on the ac side
had been omited ! Oh there was a place for a couple of caps and a comon mode inductor
but the caps wern't there and the inductor replaced with 2 jumpers.
That is all too common on the cheaper PSU's. I used to see it all the time on the older AT style ones.
Keep in mind that PC's are pretty noisy by nature,you've got high speed square wave signals running all over the place,HDD's and other things randomly reading/writing/whatever,and that can be a noisy nightmare.
Thank you all for the advice, I will take a quick look inside for missing capacitors, but if they are designed to be missing I wont bother to reverse engineer the circuit, as thats more effort than buying another one to compare, (and my knowledge of Switched mode power supplies not great). Particularly with the optically linked DAC coming.
I did a quick google, and but google was often confused by low physical noise power supplies. I cant help thinking that every ATX power supply maker claims theirs is a low noise design. That said I did find a few users who had found their brand had excessive electrical noise too. So it looks like woody and DigitalJunkie are not the only ones to report this.
I am still waiting for my DAC to arrive, to remove the ground loop and the nasty RF from my system, it now says a week to wait.
Since I had 2 quad 303 amplifiers I decided to hook them up to biamp. This produced a ground loop, admittedly not as bad as the computer but still annoying.
Since each quad 303 is declaring an earth, I could see my eventual plan on active crossing over my speakers getting harder.
An unmodified quad 303 per channel, I decided to remove the earthing from the circuit boards, This was easy, since the complete amplifier is earthed only through the signal in connection. to the driver boards.
This way the nasty HUM (and RF) on the computer power supply is not sent to the amplifier to amplify and annoy my ears.
I guess the Quads will live for years so would like to make a safer solution, (not that I see much risk) so am thinking on using the earth solution, Rod Elliott (ESP) solution,
Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
Just in case I am lucky enough one day to have kids or sell the amp on, any comments?
My DAC arrived
First the good, sound is much improved over my reference "Creative Labs SB Audigy (rev 04)". Not only this but the optical link makes the ground loop non existent. Now the bad, the DAC I chose (mostly on price) does not mute when it gets no digital signal (and formally had one) so with the computer off and the amp connected to the DAC I get a not overly loud wide band hiss.
Overall, I consider this a very effective solution to my ground loop issues, and the ATX power supply noise. I still haven taken the power supply apart and looked for missing components. I suspect its just designed in such a way that checks out lots of noise, hence my lack of action.
I had good luck using 2 12 gauge bare wires hooked as close to the ATX supply as possible to connect the amplifier board. Noise was almost eliminated compared to using one smaller wire on the end of the ATX disc supply cable. I suspect a really heavy ground cable connecting all grounds in the audio system together would be best. Remember that any current flowing on the 12 Volt line must return on the Neutral so the low resistance will decreased the voltage drop signal.
Ted
Ted
DAC + alsa + dmix + Linux >= CD quality audio.
Thanks for the suggestions.
The DAC, which effectively removed the ground loop problem, and bypassed the RF noise (~1 Mhz) with an optical cable.
I have now solved the muting issue with the DAC too. The issue caused by the cheap DAC seemed to occur only when sound apps shut down badly, including pulling the optical out while playing music (I dont know the Optical protocol but assume it has a no more music code). This was overcome by using the dmix plugin to alsa (standard linux sound drivers using the standard software mixer), so now when applications shut down badly alsa shuts down without the hiss problem.
That said I may in the future try some of the other options and its good to have them out on this thread in case others have the same issue.
- PC Based
- ATX power supply noise.
