are there SMD replacements for k170 j74
Joined 2010
Hi all,
I thought I'd try my hand at building an (almost) all smd pass amp. Is there any sub for the jfet buffer front end jfets? I could drop a BJT diamond buffer in easily enough, but it made sense to ask first.
Edit - I'm thinking an F4 - so its a complimentary pair I need
Edit edit - I'm thinking this as i've an all smt project to build soon and I want to get some practice in!
Cheers!
A
Thanks again all - I asked about pedestrian alternatives as ...it's just a buffer! it seems quite the waste to use that sort of (these days) exotica just for its low noise, when in that application the high transconductance is somewhat moot.
Try the Kuartlotron buffer (see the thread here) - uses readily available transistors and parts (from Mouser, or local RS online, etc.)
Still plenty of k170s around - can do a dcB1 buffer with/without the shunt reg
Building 'ordinary' buffers are pretty simple but getting a really 'good sounding buffer' (ie. no sound at all) to work properly isn't at all that easy and the complementary k170/j74 is one of the few simple ones, depending on the supplies
I can think of Spencer and Alweit.
Spencer is great!
Alweit's customer service leaves a lot to be desired. A number of the matched pairs that I ordered from Alweit became unmatched because of how poorly they were packaged for shipping. When I brought it to his attention the response was, "Sorry, I've heard that from other buyers as well."
