Are the SIT rectifiers usefull ?
Should we use SIT diode for rectifiers ?
Any advantage for SS, Tubes, DAC ?
What do they bring and what they don't in power regulation, please ?
Thanks in advance for your inputs. I'm in particular interrested for tubes PS to swap the rectifier tube topology and also lower PS like ones for DAC devices 😕
Uh, I made a spelling error mixing with the famous Sony transistors.😱
Here a datasheet about what I'm talking : SIC diodes !
I know nowadays some use also IC chip for that purpose as well !
WHere does it matter ? Can we hear it, or is it juist for measurement gears ?
fair advice... I even saw some do not use parralel film cap filtering for them, saying the cap is a direct high pass for high frequency noise ! Better to use a serie output resistor on each raiul before the main smoothing cap, well OT !
Ok thanks, will use more classic and better for the wallet Schottky and very fast diodes.
Not sure if I understand. You mean it's good but there is better (sorry I'm lost in translation)
Is there an agreement about its use, please, in rectifiers ?
Good for SolidState, Bad for tubes rectifiers and further soft starting layout ?
Silicon carbide (SiC) diodes have a much larger forward drop than standard Si diodes do. That could be an issue in low voltage supplies not designed to take that into account. What they get you is nearly no reverse recovery time, and for 50/60Hz, that's a nothingburger; i.e. simply not needed. In HF switchmode settings, however, it matters.
diyiggy - did you try and locate your likely applications on Fig 7 of your post #3 link ?
If you had purchased some SiC diodes and wanted to use them then it is in your interests to do some basic pre-design on how to use them - the end of section 2 of link goes a bit in to that for valve amps (ss amps would need more assessment on peak diode current consequences.
https://dalmura.com.au/static/Power%20supply%20issues%20for%20tube%20amps.pdf
