Are Parallel smaller caps better/worse than big?
After a quick search, I'm almost afraid to say the word capacitor, :cannotbe: but what are the advantages and disadvantages to parallelling many small capacitors, as opposed to using one large one.
eg) a bunch of .68uF caps in series to make a 10uF coupling cap, or 1 10uF one.
How about being used as PSU Bypass?
Has anyone done any MEASUREMENTS?
I've heard that ESR is improved. Is esr typically very nonlinear w/ respect to frequency, or could it easily be accounted for?
Nobody suggest listening tests please. While I don't deny that there are many things we can hear, that may be difficult to measure, etc.. I don't want to do a lot of screwing around at the moment. If such and such set up sounds best to you, that's fine. I'm not saying you're wrong, just that I want to see the numbers.
SO, quantifiable answers only please.
sorry to be so long winded about that, but I just spent almost 2 hours reading through what basicly amounted to flame wars based on facts that should easily have been measured.
Don't always assume that many smaller caps will be better than a few larger ones. 10x 220uF caps in parallel will have lower ESR than a single 2200uF. however, 2x 2200uF will have even lower ESR, twice the capacitance and take up less board space.
