Am about to start replacing electrolytic capacitors in a lowish end preamp and have obtained new Rubycons (mostly) from a nearby parts shop. As I examined the original capacitors to record their values, two in the phono section were distinctive with an orange wrapper and prompted a little research. Likely made by Elna and marked LR that from what I read indicates Low Leakage. I was advised by the parts store staff that it is an irrelevant distinction with modern capacitors as they would all be considered Low Leakage by 1978 standards.
There were some thread posts that concur with this while others say there would be some benefit in locating current even lower leakage replacements. In my case that would mean buying from an online US vendor and shipping to Canada. Since that would translate into $20 - $25 for two small capacitors, I cannot justify the expense.
Am I safe in my thinking that using a modern general purpose capacitor in this application would not be a downgrade from the originals as in introducing more noise? Or, just leave the originals in place?
Also, since the phono stage involves low level signal, is the capscitor's voltage rating going to be critical in this instance as long as not less than original is used? I could be wrong but from my minimal understanding, signal rarely passes through an electrolytic.
