Hey everyone!
This past week I purchased a used Yamamoto A-08s amplifier. This came after months of research and careful decision making. It's also my first foray into the tube world, after owning solid state gear for decades. As such, I'm sorry for any silly or irrelevant points I may bring up, as they will be extensions of my very basic understanding of valves and their circuits (I'm learning experientially).
Here's the situation. After a very careful unboxing and clean-up, I'm happy that the amp is visually in mint condition. I finally got to the point of powering it up last night, and immediately the rectifier tube (80) began to arc and flicker. I did a few hours of research, and it appears to me that it was not what people call 'tube flash', but rather arcing, or 'cathode stripping'. I let it go for about 3 seconds to see if it would stop, but then made the quick decision to power it back down... then immediately started researching.
From what I gathered, it seems that this is caused by the tube being 'overtaxed' from two factors -- first, on a cold startup, it is only able to operate at a fraction of it's 'warmed up' ability. Second, and compounding the issue, is that the tubes highest demand period is right at startup, when it need to charge a large 'empty' capacitor. Again, I'm sure this assessment is begging for corrections or clarifications.
In addition to any general advice people may have, I have a few specific questions:
1. What are the chances that this compromised or damaged any other component in the amp? From what I gather, some people just let the tube arc at startup and let it subside after it warms up, but I'm not so brave myself... so hopefully this means that it is 'safe' for everything else in the amp.
2. Could this issue have anything to do with the fact that I'm powering it through a Furman "IT-Ref 20i" isolation transformer? I know that each AC leg is split to carry 60v each in this design, as opposed to the 'regular' 120v + neutral... It just had me thinking, what if there is an incompatibility there somehow?
3. Could this be actually be a normal occurrence for a healthy tube that hasn't been powered on for some time? I don't know when it was last used / powered up... but if it's been years, perhaps time has some relevant effect. If this is the case, should I keep using the tube, or is it dead?
I turned to this community first because you guys seem like you really know your stuff -- thank you for any and all help!
