What's the problem with your ARC classic 60??
has it become a large annual tube consumer??
Greetings,
Tube Addict
Greetings,
Tube Addict
Hi Passfan:
What is A.G. Tannenbaum??? Would you mind to tell me more?
Tube Addict:
No problem! Just what to keep the circuit for the reference!
I want to know how to tune the Bias!
Any suggestion for the Classic 60?
How to keep the condition well?
Thanks!😛
Tube Addict:
Thanks!😛
There is a hole on the side of the unit which accepts a small screwdriver for tuning. You have probably not seen this hole 🙂 When I was working on mine (many years ago), I was quite surprised to find this hole.
If you call up AR, they will most likely send you a service manual, especially if you can provide a serial number.
Petter
Petter
ARC CL 60
Hatasa,
It is best to use an Oktet 6550´s and set the current through each tube to 65 mA, thats a dissipation of 32 Watt/tube. The holes on the side are for Servo Balance Calibration (Very difficult and time eating) Can copy the Adjustment prodedure.
Reinhard
Hatasa,
Reinhard
Hi:
Thanks for the all reply. I would liike to know is ARC havent the e-mail address? Becoz I cant find any e-mail on their website! And I think I better to ask for the service guide from them. Also I would like to order some spare parts for the CL60 and the SP11!!! Like the know and the power switch.... easy damage man!
Ofcoz I still want to ask for the circuit who can be help!
Thanks!
Thanks!
- Tubes / Valves
- ARC Classic 60 circuit
