AR series crossover
Have a play with Jeff Bagby's series spreadsheet as it does AR xo's but only 2 way. You need FRD and ZMA files and if you can't measure to get them, there is a trace program also available there.
http://www.pvconsultants.com/audio/crossover/scd.htm
Get the tweeter and mid right using the spreadsheet then start integrating the woofer. You can start with standard Butterworth 1st order values and tweak from there. It will be important to choose a woofer with the right SPL that's higher than the mid and very difficult to find the right one.
I found it a pain and ended up going active with the woofer (I cheated 😉).
