I'm finishing up my pre-amp and need to drop the plate into a wooden frame like most people use. Is there anywhere online that will do that? Or basically sell you the precut and mitered bits?
Hammond has a line of prefab Walnut enclosures with a top panel -I've never tried 'em but am tempted- it sure would eliminate a LOT of work!
Hammond Mfg. - Walnut Chassis with Aluminum Top Panel (HWCHAS Series)
Any woodworker should be able to make a base for your metal plate. I don't know where you are located but if you look around you will be able to find somebody to do the job for you. Cabinet shop worker? Starving 'Fine Woodworking' type? Retired hobby guy?
? Perhaps I'm missing a business opportunity.....?
John
John
