Doing your own 2092 pcb layout and design needs quite a bit of care.
The 2092 and output mosfets need careful pcb layout and decoupling.
For higher power design requires even more care as you will probably need mosfet gate drivers too.
I had problems with high power designs and power down.
On power down I would get a siren type noise for a couple of seconds then a massive thump through the speaker.
Apparently the 2092 doesn't like big smoothing capacitors and slow discharge on power down upsets it.
IR told me to design a reset circuit for the 2092. I used a PIC to monitor VCC and shut down the 2092 when VCC was too low.
That worked a treat.
