Anyone rolling their own horns?
I'm currently building up prototype 2 of a backloaded horn using Fostex FE168sigma units. Version one had an internal sealed cavity (not part of the horn) that caused resonance hassles. Just curious to see what else (apart from the Wallhorn Big Fun and Hedlund) people have designed and built from the theory up.
Don't get me wrong, it'd be nice but it's dependant on the back chamber of the dionysio being correct for the fostex (which I doubt). I expect they are also a bit difficult to get to Australia I'm afraid. The last problem is that my listening/loungeroom is 12ft by 18ft by 9ft and the Dionysio would overload it severely. Even some voight pipes don't have room to breathe so a full frequency horn possibly wouldn't work.
My own design is calculated for a 60Hz Fc
Spare dollars are also an issue, that's why I diy.
Happy listening
Drew
Drew,
I just got into horns too. I think you will find most have a cavity somewhere inside. The first I built was the Buschorn MKII and the second the BK201's. The next will be the Jericho. In both instances I filled the cavity with 'Polyfilla' expanding builders foam which you can get from any hardware store near you for about AU$10 a pressurepak tin. I got mine from 'Mitre 10' and I can vouch for it's effectiveness. Allow 24hr to cure and then trim the excess off with a utility knife... Works a treat
Tomcat
