I'm trying to figure out what the heck the bugleboy logo has behind the bugle near 'his' hands. Do you have a clear picture of that logo? I've been puzzling about this for weeks now, searching the net, staring at photos, etc., but I can't find a clear logo, just the tube stamping.
..Todd
..Todd
art work on a tee shirt (no affiliation with retailer)
VACUUM TUBE TEE SHIRTS
Here's a close up of one
Thanks Dave. I saw that. I think it's the cuffs on the under his hands that I was seeing, but they are overly huge on some tubes making it look like a bus parked ( or a D9 Cat maybe) behind the bugle. Ah well. Optical illusion I guess, or I'm losing my marbles, what little I have left.
Did they print that logo on boxes or datasheets? I could only find it stamped on tubes.
..Todd
..Todd
Here's a better picture of a tube than most.
http://forums.klipsch.com/forums/storage/4/849826/100_1468.JPG
I think the logo often gets distorted (and perhaps smeared) when applied to the tube.
Sorry, I just have a shirt, not a real tube. But I did stay at a Holiday Inn once!
Hi Todd,
Have a look at a bugle.
http://en.wikipedia.org/wiki/Bugle
The picture in post #2 looks like bottom part of the bugle has been removed so it doesn't interfere with the cuffs.
regards
regards
I'll have to admit I thought you were nuts about the D9 thing until I saw Dave R's link. It doesn't take a whole lot of imagination to visually finagle a bulldozer out of those cuffs!I think it's the cuffs on the under his hands that I was seeing, but they are overly huge on some tubes making it look like a bus parked ( or a D9 Cat maybe) behind the bugle.
Parenthetically, I have boatloads of Amperex 6DJ8's culled from old Tektronix oscilloscopes - but alas, none have the coveted "Bugle Boy" logo. From what I've seen on the net, the difference in value between the "BB" and "non-BB" (from ostensibly the same manufacturer) is substantial. For what reason, I have no earthly idea.
The difference in value between the same tubes (made on the same assembly line) with different branding can be blamed on... BRANDING, pure and simple. In fact, if I taught a course on branding, this would be a wonderful example of 'viral' branding... marketing executed by the market. The value needs only to exist in perception.
If you have such a tube, rejoice and enjoy the music. It's only when you sell it that you are at a disadvantage. Buying, on the other hand...
..Todd
Hi Todd,
Have a look at a bugle. The picture in post #2 looks like bottom part of the bugle has been removed so it doesn't interfere with the cuffs.
regards
Greg, that's it, you nailed it! Thank You! That particularly primitive version of the logo (in msg #4) looks to have the loop in the bugle still intact, while more advanced versions (I'll assume later versions) removed the loop to clarify things (and make it look more like a clarinet, oboe or soprano sax.).
I can sleep now.
Dave, thanks for chipping in.
..Todd
- Tubes / Valves
- Anyone have a Bugle Boy logo
