anyone able to decipher a 539 Sylvania date code?
Month 9 of 1953?
Month 5 of 1939?
What is the tube type?
Has the tube been tested?
Is the tube any good?
Date codes can not prove the condition of the tube;
And date codes can not prove the match, or non-match, to a tube of another date code, or even of the same date code.
Is this a valuable tube that will be sold for $$$?
Test first, ask questions later. :^)
Find a tube tester, and test it again. 25 years can make the tube less capable, and can do that to me too.
I have always found the best tube testers are a working tube circuit.
Yes, you have to be careful as you bring the tube up to full voltage; a Variac and one or two DMMs can monitor the tube as you slowly bring it up. Lots of work to do it that way, but worth the try.
Reactions: doctor underhill
The usual date code is YWW. 1955, week 39 (or third quarter - some used 13, 26, 39, 52 instead of the exact week). Most went to 4 digits in the '60s (i.e. 6539) . Military and some industrial customers insisted on open date codes; consumer one usually got letter codes, known only to manufacturer and dealers.
