we've been chatting on the full range driver forum, seems it is a newer eminence b102, works well in 2.5ft3 tune to 50hz I think. You can either run a 6db slope at 5khz on some tweeter (hopefully rugged, the apt80 is not as good as they used to be). Ron used one of the selenium compression drivers. Another way is to run a 12db with a tweeter (such as the ribbon in the Zu essence).
Tekton made a similar design called the Uruz that I wanted to clone. But I'm usually doing 4 different things and never finish a single one !!!!!!!!!!
Norman
