Hello everybody,
This is my first post here and I am happy this forum exists. I have built numerous projects (amplifires mainly) over the years but my knowledge is moderate so I prefer to read comments and topics here.
I would be grateful if you could inform me for some schematic for an amplifier using 2sk1530-2sj201, 70-100 watts. I found 2 pairs of them and I would like to give them a try.
Thank you in advance.Kris
Yes,this is the only schematic you can find on the net.I am wondering if anyone has tried this. I was ready to build the crescendo millenium but after reading several posts here I changed my mind.I have build 2 mini crescendos in the past but i do not want to mess with a quite "problematic" project.
Thank you very much.Kris
I 'll try this ampli mosfet simple
I hope not to end with some burnt woofers..
) like in mini crescendo (after high listenings volumes though). Either way the 2sk1530-j201 are obsolete and I want to use them.Thank you
I hope not to end with some burnt woofers..) like in mini crescendo (after high listenings volumes though). Either way the 2sk1530-j201 are obsolete and I want to use them.Thank you
I found this:
300W Mosfet power amp OCL HIFI Class AB by K1530+J201 | Circuit Project Electronic
From my brief research : K1530-J201 are vertical mosfets, and they do have a small tendancy to thermally runaway.
They should sound good if the amp is build properly.
Cheers, Stanley
- Any schematic with 2sk1530...?
