Are there any commercial manufacturers still using LM3886 or similar chip amps in their current designs?
If not, why commercial manufacturers shy away from it?
Also the above search lead me to these two patents. I wonder what they are patenting? Their specific modifications to the Typical Application circuit?
Like the Op-Amp buffer?
CN106953607A - A kind of single channel audio power amplifier based on LM3886
- Google Patents
CN105048976A - Power amplifying circuit based on LM3886 chip
- Google Patents
- Google Patents
- Google Patents
Behringer was using them in their active speakers but that's going back a few years, haven't checked if they've moved over to classD now.
I think it's also used in the Yamaha HS series active speakers. I had a Fender bass practice amp that also used the LM3886.
Micromega MyAmp uses them with resonant mode supply. Around 600.00 USD. I saw another one, sure it is limited distribution Moonriver. It is priced at 5,000.00. Did not measure as well as many DIY.
In the grey between DIY and manufacturer we have Neurochrome and Akitka. Both sell kits and completed units, Neurochrome may be kit only again.
There is a significant price difference between these two. Hear great feedback for both.
Jeff Rowland had a power amp with about 6 of them series-parallel per channel.
Jeff Rowland LM3886 Amplifiers
Jan
Jan
Somewhat expensive here but I´ll probably use it in my soon to be series produced 50W hybrid Guitar amp.
The other option is a 50W discrete amplifier based on TIP121/126 .
The deal breaker either way will be whether I can secure a supply of 50-100 chipamps or not, don´t want to get stuck with a lot of empty PCBs.
If not, or complicated, will go the discrete route ..... meaning yes, they are still used, still an interesting option for new designs.
Output current is the only limiting factor. For 8 ohm load a LM3886 is perfectly suited. For 4 ohm loads, usually dipping down below 3 ohms at some frequencies a single chip struggles.
Many have paralleled them to allow driving almost any loudspeaker. There is more to paralleling them than connecting two chips.
The Jeff Rowland model with three in parallel and bridged was an example that these can output real power. A friend in New Braunfels purchased one, loved it. He sold it and had sellers remorse. Looked for another. Said it was fantastic. Realized that after replacing it.
I can usually spot amplifiers that use a LM3886 chip. If you see a 50 watt power rating for 8 ohms and 60 - 70 ohms for 4 ohms the majority of recent build amps use a single LM3886. Like the new Leak.
That is quite a reassuring message. I was just wondering whether using in new designs is a bad idea.
These are some other using LM3886
Moon River 404
Cambridge axa25 - IIRC
Peachtree - IIRC
Audio Analogue
Moon River 404
Peachtree - IIRC
Audio Analogue
- Chip Amps
- Any manufacturers still using LM3886 in their current designs?
