Just wondering if there are any other DAT guys here.
I used my Sony DTC-57 DAT to make digital copies of CD's, before there were computer CD copiers. Today DAT tapes are being sold at close-out prices.
MLStrand56
MLStrand56
I still have my good old DTC-57ES waiting for major refurbishment. The drive has mechanical problems which are well-known for that Sony series.
Rundmaus
Rundmaus
DTC-57ES issues?
MLStrand56
What exactly are these "well known" issues? From what I've seen, All the Sony home DAT's are pretty much the same. Are there model specific issues?I still have my good old DTC-57ES waiting for major refurbishment. The drive has mechanical problems which are well-known for that Sony series.
MLStrand56
Here are a few links, google will readily present more if you search for DTC-57 drive problems:
DAT-Heads Digest #463
DTC-57ES transport repair - AudioKarma.org Home Audio Stereo Discussion Forums
Servicing a SONY DAT machine (Pictorial) - AudioKarma.org Home Audio Stereo Discussion Forums
Sony DAT 3 motor machines
I have done some videos on repairing the 3 motor machines. These are the most troublesome but once you know what to do with them they are quite easy to repair. As someone here has said, most of the Sony DATs use the same transport, with minor modifications but the dearer models use a 4 motor version with direct drive reels which is better - although even these can need a tweak of the pot that drives the take up spool.
Anyway, if you have a 3 motor deck ie the DTC-57ES, 750, 59ES, 60ES, ZE700, P7, 690, 670, 790, A6 or PCM-R300 take a look here:
Sony DAT Digital Audio Tape Repair 2a Tape Loading Problems - YouTube
Sony DAT Digital Audio Tape Repair 2b Tape Loading Problems Continued - YouTube
Sony DAT Digital Audio Tape Repair 2c More Tape Loading Problems - YouTube
Sony DAT Digital Audio Tape Repair 3 Thoughts on back tension - YouTube
Also here's how to change the head amp caps, something that should be done to all Sony DATs except the PCM-70x0 models:
Sony DAT Digital Audio Tape Repair 1 Changing the capacitors in the head amplifier - YouTube
