OK - I built a BrianGT gainclone (non-inverted 3886) and I built a pair of short interconnects to link it with a pre-amp. The initial interconnect configuration was two runs of silver wire insulated with cotton in a twisted pair. I use this interconnect throughout my system without any noise problems.
However, when connected with the amp, it produced a mid-audible buzzing. Mid-audible means it was present on normal listening levels - just enough to be annoying. If the interconnect was replaced by any normal double shielded coaxial cable the noise was gone. I tried yesterday adding a shield to the cables - very heavy copper braid. Tried with a single end connection to the ground and both end connection - the results were the same - the buzz was transformed into slight hum but this time barely audible and almost not influenced by the volume level. Although the results are better I still do not understand what is happening here. Is the amp that sensitive to EMI/RFI pickup? Anything that I can to the amp to stop this? Poly-caps at the input RCAs maybe?
it is grounding issue.
check this thread:http://www.diyaudio.com/forums/showthread.php?s=&threadid=115698,wish helps.
zang
zang
I do not think it is a grounding issue. I have no noise with normal double shielded coaxial cable. It is only my home made interconnect that is creating a problem. I only wonder if there is some way of attenuating the RFI input to the amp or I sould change my interconnect.
... BTW my grounding is done as per your schematics including a ground breaker form eliott sound projects.
I suspect that the chipamp does not have any passive band limiting filters on the input to the power amp nor at the RCA input terminals.
I too suspect that the grounding can be improved.
A buzz is more usually associated with misusing the PSU zero volt connection as the audio star ground
Joined 2003
Sounds to me like your twisted pair is picking up noise from the AC mains. Is the cable running in any proximity to AC mains? Does the amplitude of the hum change when you move the cable around?
My advice would be to stick with the shielded cable, connecting the shield to ground at one end only.
is that shielded two core or using the shield as the return?DcibeL said:Sounds to me like your twisted pair is picking up noise from the AC mains. Is the cable running in any proximity to AC mains? Does the amplitude of the hum change when you move the cable around?
Joined 2003
Sorry, yes shielded two core. I have found it to be most effective in removing induced noise and hum.
Well - first about the cable(s). The power cable goes into the box in the centre - the input cables connect at the far ends of the box. The power cable is shielded.
Inside - the signal star ground is connected to the input of the ground breaker (diode bridge, cap and 10ohm resistor) - exit from the ground breaker connects to the chassis and the mains ground wire. Signal star ground point is formed by connecting to ground wires from the PCBs. I do not have a direct wire connection of the signal grounds to the star point. I was planning to do this at some stage. PSU zero volt is not connected to the star ground.
Signal input cables are twisted pair and shielded (pseudo balanced)- no difference between single or both end shield connection. At least not in the hum presence - probably yes in overall sound quality (have not had any time to check). Shield is only copper braid (very heavy - at least 96% coverage) but without foil shield. Standard dual shield coaxial had no hum issue but the sound was dreadful.
Just to make things even more interesting. Yesterday hum disappeared. Simply nothing - changed levels, inputs - simply not there. On a shorted input of the preamp - simply dead silent.
Any suggestions?
Any suggestions?
hi,how many signal ground was connected to the ground breaker?
i think it is better to connected all RCA plate(passive signal)together and then use a single wire connected it to the ground breaker.otherwise the interconnect cable will collect noise from outside.
Well, honestly I do not see the difference apart from the fact that one chanell (I have dual mono configuration) will have longer ground wire path then the other. This in my opinion ruins the symmetry - apart from slight increase in resistance which is probably not an issue. My amp boards are less then 5cm from the input RCAs. So the wires from RCAs to PCBs are very short. On the PCB they are on the common ground plane and then two wires of maybe 15cm in lenght go to the ground breaker.
I will try as you said and see if it makes any difference. Thanks
Just to report
I rewired my interconnects - the shield is now only linked to one end (pseudo balanced configuration). I added another ground line - from the input ground directly to the star ground connection.
No hum - well - the amp is dead silent to be fair.
Something fishy was happening there, I will follow up if I notice anything strange.
Thanks for all help.
I think you have described the Leach method of connecting the input RCAs to audio ground. I have found this to be effective in the majority of two channel builds.decky said:I rewired my interconnects - the shield is now only linked to one end (pseudo balanced configuration). I added another ground line - from the input ground directly to the star ground connection.
Ive seen other builds where they run the rca input grounds to the star ground and others say to keep them isolated from the chassis. I guess it is best to try it both ways to see what works better?
They are definetely isolated from the chasis - the chasis is connected on the other side of the ground breaker.
these two options describe the same thing.artfuldodger said:Ive seen other builds where they run the rca input grounds to the star ground and others say to keep them isolated from the chassis. I guess it is best to try it both ways to see what works better?
The RCAs are isolated from the chassis AND the RCA grounds are run to the audio ground, also called the star ground .
Yes that would mean the same thing meaning whether they were grounded to the chassis or a wire to the star ground on the chassis. My question was should they be grounded to the chassis at any point before reaching the inputs of the amp board?
http://www.briangt.com/gallery/nigc-mlabuda
artfuldodger said:Yes that would mean the same thing meaning whether they were grounded to the chassis or a wire to the star ground on the chassis. My question was should they be grounded to the chassis at any point before reaching the inputs of the amp board?
the wiring is no good.there are redundancy wires.
check this post,http://www.diyaudio.com/forums/showthread.php?postid=1403905#post1403905
zang
No, do not ground the input or output terminals to the chassis.artfuldodger said:........whether they were grounded to the chassis.......
- Chip Amps
- An interesting interconnect problem
