I'm going to be setting up a system to pipe audio into all my rooms in my house and my patio - 4 separate zones
I will be controlling everything separately via a PC so each zone can have different music playing.
Since these are mid-level ceiling speakers for 'background' music the amps don't need to be powerful but I'd like them to be decently clean/clear.
I'd like to use a digital amp due to size and power requirements. Just wondering if anyone has done this with a T-amp or any of the DIY kits... what you used, what case you used, how it turned out, etc.
Thanks for the tips/suggestions!
Multiple T-amps right at each speaker would be great for such a system. Just make sure to use shielded signal wiring, and possibly some differential line driver and receiver circuitry, to help avoid noise if you go that route.
I can recommend the Sure Electronics TA2024 T-Amps, for $25 delivered.
ebay.com
They run well from 12v SMPS, but I advise that you at least remove the 2 unnecessary input capacitors if you want them to sound really nice.
Full thread here
ebay.com
Full thread here
I'd be interested to know more about this. Any suggestions as to where I should look?
Tim
Tim
You can have a look at www.xlobby.com (there is a freeware version, have a look in the forums). With a bit of ******** around you can setup 4 separate zones with separate control (look for kx drivers thread). I haven't done it myself so I can't remember if it is multi-source. Cheers, cc&c.
XLobby is what I'm planning to use... BUT development on it is SLOW and I'm loosing patience. I'm starting to look at Girder5 & Netremote
Currently I use XBMC (on the original xbox) and it is being ported to Linux. So, I'm hoping that will be a viable solution once it reaches its first release... and it is free.
