Hi All,
First time posting and new to the DIY scene, so hopefully someone here can help me out!
I've 'successfully' built my first amplifier at home (just the basic starving student with 19J6's), but am running into an issue with the volume of the output.
I've got 50 OHM impedance headphones hooked up and have lowered the volume to about as low as it can go.
I find that even at the lower volume settings (not even a 1/4 of a turn around the pot.) can I handle the sound generated.
Any suggestions to maybe taper or modify the output?
Side note, I believe that the pot could possibly be wired backwards as right is low and left is high.
