Folks:
I'm looking for ideas for a new integrated amplifier for my parents. About 15 years ago I built them a simple LM3875-based integrated amplifier which they installed in my father's studio. My parents spend a lot of their time in that studio, which also serves as their reading room (he paints and they do a lot of reading) -- that amplifier is probably on at least 8 hours a day and they've derived a lot of pleasure from it. I'm considering building them a better-quality amp and would appreciate some suggestions.
My design criteria is:
1. The amp needs to be reasonably efficient. I've built a lot of Nelson Pass's designs and while I'm a big fan, big heat-generating Class A amps probably aren't the way to go for this project.
2. The amp has to be well-designed and not readily subject to over-heating. The amp will be on a small shelf with moderate air flow. Again, it will likely be on for extended periods of time.
3. It needs to sound at least as good as an LM3875 amp.
4. The speakers are 87 dB bookshelf loudspeakers. High volume will not be required.
5. Simpler is better (Mies van der Rohe was right, in my opinion).
Thank you in advance for the input.
Regards,
Scott
Regards,
Scott
