Hi all...my new mustang came with 2 8" door subs and 2 crummy little amps, about 100W each. The factory woofers are 2 ohm DVC but I replaced them with 8 ohm Seas CA21RE's -- needless to say I need new amps. I think I can make 2 AMP3 kits from 41hz.com, each bridged for about 50W into 8 Ohms.
What I'm curious about are the details, since I'm very new at this. The factory amps are hooked up with harnesses, so I need to figure out which wire is which and how best to connect them to the new amps. I also need a way to determine if the factory amps are using line-level or high-level inputs; they look like speaker cables going in, but it would be good to be sure before I shell out for a LOC.
Finally, what else do I need to know here?
