So I bought the service manual. . . Still chasing the static on the right channel that goes away under load and isn't in the preamp or tone sections.
And, the headphone section feeds off the speaker terminals. Of course its very weird that you can shut off the speakers and the headphones play clean. Turn the speakers back on and the right channel gets scratchy at moderate to low volume.
The change appears with-out touching the volume pot.
I was wondering if there could be a goofup somehow in the DC detector circuit, pre drive, diff amp, or power amp?
Any clues? This is a lot bigger amplifier than I'd normally fool with.
Lightly loaded running headphones works perfectly; but, just punch the speaker button "main" and the right side goes staticy. Technics SA5370 receiver
Thanks for your help!!
