Does anyone know what might cause a 1000Uf 250V rail cap to blow in an amp ?
I dont see anything else wrong with the amp everything tests fine.
It only blew 1 cap it blew out the bottom
What amp is it in?
If you monitor the positive and negative rails, does either increase as you drive the amp with a signal while connected to a speaker?
