I've read some about failure modes... and I know that some amps when they fail - can cook drivers because they pass the full rail voltage. I know some amps have DC protection and some don't.
I know that heat/voltage are factors in transistor failure, but if an output is going to fail open or shorted --- is that far more likely to fail when it's being pushed hard? In other words, if it's not being pushed very much....... are the transistors that much safer?
How often does an output transistor fail just in routine service, if it's not being stressed? From what I've read, open vs shorted failures seem to either be 50/50 or more likely shorted. Seems to depend on who you ask.
I've seen some DC protection circuits... I'm just trying to determine if I can use a couple amps with some more expensive drivers, or if I'm better looking for some new amps that have DC protection that might keep the drivers........ safer.
I realize my question may be a "duh, transistors can fail at any time... they are more likely to fail when being pushed hard..." - just curious if that was in fact reality or not.
