hi, i bought a helder hifi tripath ta2020 amplifier a few years back
i managed to make the chip explode as in the photos below
what is the likelihood of the amp working if i replace the chip? or will other components need replacing also?
i have found replacement chips on ebay
TA2020-20 Integrated Circuit from Tripath | eBay
i also need some advice about creating a finished amp with the helder board if i can fix it,
i would like to build an enclosure with a phono pre amp, i have found this kit for sale
United Kingdom ear834 12AX7/ECC83 Tube MM RIAA Phono Amplifier DIY KIT For HiFi | eBay
would this ear834 tube amp pair ok with the helder tripath board? or is it a bit over kill for a cheap tripath amp? if so can anybody recomend a cheaper phono pre amp stage i can pair with the helder amp?
i also require advice about wiring all of this together and other components to use like volume pot and psu for the tripath amp, ideally i would like a phono input going through both amps, an aux input through just the tripath amp and possibly a bluetooth module and also volume control
i will be using the amp to drive a pair of G chang cabinets with pioneer 8" full range drivers
any advice and design ideas you have would be greatly appreciated
Thanks in advance
Ben
Thanks in advance
Ben
