I need some help with a new design if it is possible please. I am a first year Electrical Engineering student, so my knowledge of amps and all its components are still stretched thin.
The idea that I had in mind, was to build a amplifier for my car. I have been looking around a little bit on the forums for schematics and have found quite a few. I am, however, unsure if these amplifiers will be able to function on only a 12v input.
At this time my car only has two 6x9", 260W , 4 ohm speakers in. So building a low watt amplifier might be more suitable, however, if i should decide to buy a sub later, then it would be more logical to rather build a high watt amplifier.
If it is possible, and anyone that would share some insight (or some schematics 😛) for such a amplifier it would be greatly appreciated
Kind Regards
Ruan
Kind Regards
Ruan
a 12v amp would fit
but in order to get more than a few watt into this
you woud have to make a voltage doubler
it akes more voltage to increase watt
even with 4 ohm lsp
even with 4 ohm lsp
A bridge amplifier with a CFP output stage will deliver 20W/4R in a car.
A/D/S sold some nice units built like this, they sounded quite good.
An IC solution with board layout.
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000161.pdf
A class D or T amp would probably be the best for a car. Some places I've looked at are:
Class D Audio Car Audio - PRODUCTS
They only sell pre-built but have a good reputation. Also sell an smps module.
41Hz Audio - News
They have a big selection class T Tripath amps. Was looking at amp3 or amp9 (4 channel) for the car but amp11 would be better for subwoffer. No smps kit there.
ESP Projects Pages - DIY Audio and Electronics
ESP has a lot of amp and other projects with schematics. See project 89 for discussion on an smps. A great source of info (go to the bottom of the page and click on main index link).
SMPS Switching Power Supply Design: Circuits and Schematics
Talks more about smps theory and has a few links at the bottom for schematics.
http://www.diyaudio.com/forums/car-audio/31614-making-car-amplifier-smps-tl494-dc-protection.html
A car smps discussion right here on diyaudio.
DIYMA.com - Car Audio Forum & 12 volt Community Board
A forum that focuses on car audio more but has less DIY projects. Remember reading a thread about a guy adding a 41hz amp to his double din head unit.
Hope that helps. Most of the theory is over my head so I'm still one of the beginners that would need a kit or a PCB with good instructions. 😉
41Hz Audio - News
OK, how about a Toshiba part?
http://www.semicon.toshiba.co.jp/docs/datasheet/en/ASSP/TB2921AHQ_en_datasheet_090203.pdf
78% efficient at full power, vs 81% on a TA2020.
DJK,
I can't find that graph in the link you posted.
Does a ClassAB amplifier powered from a single 13.2Vdc supply really draw ~900mA of current when the output is 200mW into 4r0?
If that is unrealistic then why should be believe that the ClassKB draws ~500mA under the same supply and output conditions?
Good circuit, but essentially a copy cat of stmicro TDA7560...
" DJK,
I can't find that graph in the link you posted."
The graph is from their car audio selection tree.
"Does a ClassAB amplifier powered from a single 13.2Vdc supply really draw ~900mA of current when the output is 200mW into 4r0?"
It doesn't make sense, does it?
I can't find the data sheet for their Class KB part.
My calculation shows all four channels at 200mW plus Iq should draw about 14W at 13.2V (1.074A)
I can think of a way to get a curve like the KB curve, but it would require a rail switch like the one in the National Semiconductor patent on the bridged LM3886, and a buck-mode switching regulator for the lower rail. You could put all the extra stuff inside the IC, except the inductor.
"Good circuit, but essentially a copy cat of stmicro TDA7560... "
I think it may be better in some respects, the pin-out is the same too.
__________________
__________________
- Amp Advice
