Amp advice for Korn/metal sound
So I am thinking about buying the Randall RX120RH and RX412 Half Stack Amp, I know it would give me a metal sound but I wanted to play some Korn songs on it and I am not sure if it would give me a guitar sound like them. Anybody know about this? I would also want to know if It would be a good amp for bass too. If you guys don't think this would be a very good amp then give me a suggestion. My budget is $600. Thanks.
Any one at there that was in the situation to put jumper from RC-RH Ecobee 3 vs Ecobee 4 - Smart thermostats for HVAC system ? We already installed and wire correctly as setting but do not work. I has to put the R wire to RH to made heat work and if I need cool, has to moved to RC when according to thermostat will do it onself. Any help please
You will NOT be able to buy the necessary Mesa Boogie Dual Rectifier and matching 4 x 12" MESA cabinet with that, loaded with Mesa Celestion V30 custom built for them, so get the best Metal amp you can get within budget and practice a lot, "sound is in your fingers"
Oh, and it will be a TERRIBLE Bass amp, although you might practice with it in a bedroom setting.
