Altium Newbie needs help
Hey guys...
I'm working on some diagrams here and i got to the point where i need to verify schematic integrity so I can start laying out the board.
Here's where my headaches come in:
14 Warnings and 79 Errors 🙁
Class Document Source Message Time Date No.
[Warning] DSP-DAC.SchDoc Compiler Nets Wire ABCLK1 has multiple names (Sheet Entry U_DAC1-ABCLK(I/O),Net Label ABCLK1) 13:03:59 18.03.2014 1
[Warning] DSP-DAC.SchDoc Compiler Nets Wire ALRCLK2 has multiple names (Sheet Entry U_DAC1-ALRCLK(I/O),Net Label ALRCLK2) 13:03:59 18.03.2014 2
[Warning] DSP-DAC.SchDoc Compiler Nets Wire AMCLK has multiple names (Sheet Entry U_DSP1-ACLKOUT(Output),Sheet Entry U_DAC1-AMCLK(Input)) 13:03:59 18.03.2014 3
[Warning] DSP-DAC.SchDoc Compiler Nets Wire ASDATA(1..9) has multiple names (Net Label ASDATA(1..9),Sheet Entry U_DAC1-ASDATA_IN(1..8)(Input),Sheet Entry U_DSP1-ASDATA_OUT(1..9)(Output)) 13:03:59 18.03.2014 4
[Warning] DSP-DAC.SchDoc Compiler Nets Wire ASDATAIN(1..8) has multiple names (Sheet Entry U_DSP1-ASDATA_IN(1..9)(Input),Net Label ASDATAIN(1..8)) 13:03:59 18.03.2014 5
[Warning] DSP-DAC.SchDoc Compiler Nets Wire AVDD has multiple names (Net Label AVDD,Sheet Entry U_DAC1-AVDD2(Input)) 13:03:59 18.03.2014 6
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BBCLK2 has multiple names (Sheet Entry U_DAC2-BBCLK(I/O),Net Label BBCLK2) 13:03:59 18.03.2014 7
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BLRCLK1 has multiple names (Sheet Entry U_DAC2-BLRCLK(I/O),Net Label BLRCLK1) 13:03:59 18.03.2014 8
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BMCLK has multiple names (Sheet Entry U_DSP2-BCLKOUT(Output),Sheet Entry U_DAC2-BMCLK(Input)) 13:03:59 18.03.2014 9
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BSDATA(1..9) has multiple names (Sheet Entry U_DAC2-BDSDATA(1..8)(Input),Net Label BSDATA(1..9),Sheet Entry U_DSP2-BSDATA_OUT(1..9)(Output)) 13:03:59 18.03.2014 10
[Warning] DSP-DAC.SchDoc Compiler Nets Wire GND has multiple names (Sheet Entry U_DSP1-AVDD1(Passive),Net Label GND) 13:03:59 18.03.2014 11
[Warning] DSP-DAC.SchDoc Compiler Nets Wire IOVDD has multiple names (Sheet Entry U_DSP1-IODVD(Input),Sheet Entry U_DAC1-IOVDD(Input)) 13:03:59 18.03.2014 12
[Warning] DAC1.SchDoc Compiler Nets Wire DGND1 has multiple names (Net Label DGND1,Net Label DGND2,Net Label DGND3) 13:03:59 18.03.2014 13
[Warning] DAC1.SchDoc Compiler Nets Wire AGND1 has multiple names (Net Label AGND1,Net Label AGND2,Net Label AGND3,Net Label AGND4,Power Object GND) 13:03:59 18.03.2014 14
[Error] DAC1.SchDoc Compiler Port ADSDATA(1..8) not matched to Sheet Entry at 30,40 13:03:59 18.03.2014 15
[Error] DAC1.SchDoc Compiler Port AVDD not matched to Sheet Entry at 170,680 13:03:59 18.03.2014 16
[Error] DAC2.SchDoc Compiler Port BDLRCLK not matched to Sheet Entry at 30,70 13:03:59 18.03.2014 17
[Error] DAC2.SchDoc Compiler Port BDBCLK not matched to Sheet Entry at 30,90 13:03:59 18.03.2014 18
[Error] DAC2.SchDoc Compiler Port BMCLKI not matched to Sheet Entry at 30,160 13:03:59 18.03.2014 19
[Error] DSP1.SchDoc Compiler Port ASDATA_IN(1..8) not matched to Sheet Entry at 1030,650 13:03:59 18.03.2014 20
[Error] DSP1.SchDoc Compiler Port ASDATA_OUT(1..8) not matched to Sheet Entry at 1030,680 13:03:59 18.03.2014 21
[Error] DSP1.SchDoc Compiler Port AVDD not matched to Sheet Entry at 50,490 13:03:59 18.03.2014 22
[Error] DSP2.SchDoc Compiler Port BSDATAOUT(1..8) not matched to Sheet Entry at 1030,680 13:03:59 18.03.2014 23
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry ASDATA_IN(1..8) not matched to Port at 640,610 13:03:59 18.03.2014 24
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry ASDATA_OUT(1..9) not matched to Port at 450,610 13:03:59 18.03.2014 25
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry ASDATA_IN(1..9) not matched to Port at 260,610 13:03:59 18.03.2014 26
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry AVDD2 not matched to Port at 800,540 13:03:59 18.03.2014 27
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry AVDD2 not matched to Port at 800,360 13:03:59 18.03.2014 28
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry BBCLK not matched to Port at 640,360 13:03:59 18.03.2014 29
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry BLRCLK not matched to Port at 640,380 13:03:59 18.03.2014 30
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry BSDATA_OUT(1..9) not matched to Port at 450,420 13:03:59 18.03.2014 31
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry AVDD1 not matched to Port at 260,510 13:03:59 18.03.2014 32
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry AVDD1 not matched to Port at 260,320 13:03:59 18.03.2014 33
[Error] DSP-DAC.SchDoc Compiler Sheet-Entry BMCLK not matched to Port at 640,400 13:03:59 18.03.2014 34
[Error] DSP-DAC.SchDoc Compiler Duplicate Component Designators R* at 215,360 and 215,350 13:03:59 18.03.2014 35
[Warning] DSP-DAC.SchDoc Compiler Sheet contains duplicate ports Port AVDD at 170,680 and 170,680 13:03:59 18.03.2014 36
[Warning] DSP-DAC.SchDoc Compiler Sheet contains duplicate ports Port AVDD at 170,680 and 50,490 13:03:59 18.03.2014 37
[Warning] DSP-DAC.SchDoc Compiler Sheet contains duplicate ports Port AVDD at 50,490 and 50,490 13:03:59 18.03.2014 38
[Warning] DSP-DAC.SchDoc Compiler Nets Wire NetR*_1 has multiple names (Sheet Entry U_DSP1-ACLKOUT(Output),Sheet Entry U_DAC1-AMCLK(Input)) 13:03:59 18.03.2014 39
[Warning] DSP-DAC.SchDoc Compiler Nets Wire NetU4_53 has multiple names (Sheet Entry U_DSP2-BCLKOUT(Output),Sheet Entry U_DAC2-BMCLK(Input)) 13:03:59 18.03.2014 40
[Warning] DSP-DAC.SchDoc Compiler Nets Wire IOVDD has multiple names (Sheet Entry U_DSP1-IODVD(Input),Net Label IOVDD) 13:03:59 18.03.2014 41
[Warning] DSP-DAC.SchDoc Compiler Nets Wire DGND1 has multiple names (Net Label DGND1,Net Label DGND2,Net Label DGND3,Net Label DVDD) 13:03:59 18.03.2014 42
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BSDATAIN(1..8) has multiple names (Net Label BSDATAIN(1..8),Net Label BSDATAIN(1..9)) 13:03:59 18.03.2014 43
[Warning] DSP-DAC.SchDoc Compiler Nets Wire BDSDATA(1..8) has multiple names (Net Label BDSDATA(1..8),Net Label BSDATA(1..9),Sheet Entry U_DSP2-BSDATA_OUT(1..9)(Output)) 13:03:59 18.03.2014 44
[Warning] DSP-DAC.SchDoc Compiler Nets Wire AGND1 has multiple names (Net Label AGND1,Net Label AGND2,Net Label AGND3,Net Label AGND4,Sheet Entry U_DSP1-AVDD1(Passive),Net Label GND) 13:03:59 18.03.2014 45
[Warning] DSP2.SchDoc Compiler Net NetU4_53 has no driving source (Pin U4-53) 13:03:59 18.03.2014 46
[Warning] DSP-DAC.SchDoc Compiler Net AVDD has no driving source (Pin C95-1,Pin P1-3,Pin R*1-1,Pin R*2-1) 13:03:59 18.03.2014 47
[Warning] DSP-DAC.SchDoc Compiler Net ASDATAIN(1..8) has no driving source () 13:03:59 18.03.2014 48
[Warning] DSP2.SchDoc Compiler Net BSDATA_OUT(1..8) has no driving source () 13:03:59 18.03.2014 49
[Warning] DSP1.SchDoc Compiler Net ASDATA_OUT(1..8) has no driving source () 13:03:59 18.03.2014 50
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK1 13:03:59 18.03.2014 51
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK10 13:03:59 18.03.2014 52
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK3 13:03:59 18.03.2014 53
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK4 13:03:59 18.03.2014 54
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK5 13:03:59 18.03.2014 55
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK6 13:03:59 18.03.2014 56
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK7 13:03:59 18.03.2014 57
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK8 13:03:59 18.03.2014 58
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ABCLK9 13:03:59 18.03.2014 59
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire AGND(1..4) 13:03:59 18.03.2014 60
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK1 13:03:59 18.03.2014 61
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK2 13:03:59 18.03.2014 62
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK3 13:03:59 18.03.2014 63
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK4 13:03:59 18.03.2014 64
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK5 13:03:59 18.03.2014 65
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK6 13:03:59 18.03.2014 66
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK7 13:03:59 18.03.2014 67
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK8 13:03:59 18.03.2014 68
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire ALRCLK9 13:03:59 18.03.2014 69
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire AVDD 13:03:59 18.03.2014 70
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire AVDD 13:03:59 18.03.2014 71
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK1 13:03:59 18.03.2014 72
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK10 13:03:59 18.03.2014 73
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK2 13:03:59 18.03.2014 74
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK3 13:03:59 18.03.2014 75
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK4 13:03:59 18.03.2014 76
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK5 13:03:59 18.03.2014 77
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK6 13:03:59 18.03.2014 78
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK7 13:03:59 18.03.2014 79
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK8 13:03:59 18.03.2014 80
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BBCLK9 13:03:59 18.03.2014 81
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK1 13:03:59 18.03.2014 82
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK10 13:03:59 18.03.2014 83
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK2 13:03:59 18.03.2014 84
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK3 13:03:59 18.03.2014 85
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK4 13:03:59 18.03.2014 86
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK5 13:03:59 18.03.2014 87
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK6 13:03:59 18.03.2014 88
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK7 13:03:59 18.03.2014 89
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK8 13:03:59 18.03.2014 90
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire BLRCLK9 13:03:59 18.03.2014 91
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire DGND(1..3) 13:03:59 18.03.2014 92
[Error] DSP-DAC.SchDoc Compiler Duplicate Net Names Wire NetR*_2 13:03:59 18.03.2014 93
I hope someone can chime in and tell me what im doing wrong or at least explain how to fix this :/
