I'm in the middle of building a pair of Zaph's BAMTMs and instead of going with the Seas tweeters, I went with the HiVi SD1.1-A found here. I am regretting not going with the Seas now but I hope the HiVi will produce a reasonable quality response. I know the frequency response is not similar to the Seas along with some other things, before I goto order the crossover components, I was wondering if there was any alterations to the component list I should make? Any help would be appreciated.
And on another note, my searches have been coming back empty on what type of amplifier to employ for these speakers? I'd love to build one and I am all about the DIY, I just haven't had any hands on experience with audio fidelity of this amplitude. Thanks in advance!
I would save my money for the Seas tweeter. What makes the design work is the ability of that tweeter to cross over low. Not only will this require a complete redesign of the crossover, I doubt your tweeter will play low enough to work with the woofers. It is a great design that sounds fantastic with 75 - 100 watts of clean power.
Your asking for trouble changing the tweeter, I don't recommend it at all.
Its not totally unworkable with the SD1.1 but some redesign and modelling
would be required for the new sensitivity and series resistor value.
There is no guarantee the SD1.1 can handle the same maximum levels.
Any decent 4 ohm capable amplifier should be fine. FWIW buying a used
and rebuilding it is far easier that starting from scratch, and far cheaper.
rgds, sreten.
http://sites.google.com/site/undefinition/diy
http://www.zaphaudio.com
http://www.rjbaudio.com/Audiofiles/FRDtools.html
rgds, sreten.
Yes you are missing something. The tweeter filter is only part of the crossover. If you found a crossover that gives the same frequency and phase response as Zaph designed into his on the same baffle width, you could substitute it. That is not the case with the filter that you linked to.
Notice that Zaph gets a 4th order 1500 Hz response out of his filter. The one you linked to rolls the tweeter off at about 2300 Hz third order You'd end up with a big hole in the response.
- Alterations to BAMTM crossover?
