Altec Throat 30162
Administrator
Joined 2004
Does anyone have an Altec 30162 horn throat handy? It's the throat that goes in the 802 and 805 multicell horns .
I need a measurement and mine are 100s of miles away in storage. Thanks!
Administrator
Joined 2004
Hey thanks! :up:
In order of importance:
  1. The dimensions of the rectangular opening. (is it centered?)
  2. The dimensions of the rectangular flange
  3. Distance between the two flanges.
I'm hoping to make a pair of 2" throats for my BMS coaxial driver. I had to use a 2" to 1.4" adapter "backwards" to get the driver on the 803. Starting with the 2" throat would be better, I hope.
Joined 2010
Scale is millimetres.
Rectangular flange is symmetrical. Overall size is approx 108 mm x 80 mm. Opening is approx. 67 mm x 35 mm.
Flange to flange distance is approx. 116 mm.
